Mercury 15hp carberator main needle seems offset or bent is that normal?
OttawaPhil
Trying to help a friend fix his motor which is not running real well since he bought it used.
Took apart the carb and saw the needle is not centred. Is that normal? Here is a picture.
Thanks!
That appears to be normal for that tube.----What trouble shooting has been done?-----------It is not always a carburetor problem.
The needle and seat are under the little brass trip arm. Not the siphon tube you are showing in your picture
OttawaPhil
Ah ok, thanks for clarification. Ok so pickup tube doesn't need to be straight.
I think his problem is fuel pump or hose related.
He loses pressure on the fuel hose then pumping the bulb makes it go again for a bit.
Texasmark
Since you have the carb apart, hook up the fuel line to it as in normal operation. Get another pair of hands. Have the other pair squeeze the bulb while you: With the carb in it's normal position, bowl off, float hanging down, carefully push the float up toward the top (casting) of the carb until it is level with (parallel to) the mating flange where the bowl attaches.....fuel is dribbling out of the carb at this time.
When you get to and hold the float in this position, the bulb should become firm (sorta hard) and the fuel dripping from the carb should stop If it is as mentioned, then suspect something else like fuel pump or cracked line between the bulb and the tank.
If the bulb is still not firm attempt to gently continue pushing the float up into the bottom of the upper casting. If you can get it firm that way, and the flowing fuel stops, the float needs to be properly adjusted.
If it is still not firm then you could have a bad carb. needle valve/seat....under the stainless steel pin in your picture on the left side (valve that lets fuel into the bowl), or you have cracked lines somewhere between the bulb and the carb, or the check valve in the bulb is leaking.
OttawaPhil
We took the boat out and did some further testing. We now have good leak free fuel line that does not lose pressure. Once you pump up the fuel line ball it will start on the first pole and idles fine as well as low throttle performance. If you try to go higher throttle it will bog and then stall. If you pump up the pressure in the fuel hose with the bulb then it will run great get on plane and seems to work well, but if you do not pump up the hose once in a while then it will not keep going and will bog come off plane and stall. What do you guys think? It seems like fuel pump problem to me, but I am not an outboard export like you guys are. Thank you very much for your help.
It is a Marriner 9.9 "with a 15hp carb"'according to the seller.If you think it is a fuel pump problem what parts do we need to replace? Thanks!
Texasmark
Re-read what I said above. You are about half way through it according to your report.
