Hi,
I bought a 1985 SeaNymph SS-175 just over a week ago powered by a 1985 or 1986 Merc 90 HP inline 6 based on the serial number. It ran fine on the test run, although it was a bit hard to start from cold. I had read that motors have individual personalities related to starting, so I wasn't really turned off by that. (My mistake!) Once warmed, it started fine with a blip of the key.
I used it a few days later and ditto, although it started even harder. It ran fine and started mostly OK after warming. Since yesterday, it won't start at all.
I have spark on only cylinder 2 (from the top) and no others. This "Tower of Power" is a CDI engine with 6 individual coils, 2 switch boxes and NO distributor.
I have a Seloc manual for reference. Compression is 135-140 on all cylinders. It is a dual battery setup and cranks quickly and for a long time.
I cleaned all terminals on the switch boxes and coils even though most looked fine. Resistance values per Seloc and CDI Electronics seem to be within spec.
I jumped the wire that goes to the coil 2 terminal from the upper switchbox to all the other coils and I get strong spark from all other coils. I believe that confirms that all the other coils are are also good. However, I can't get a spark from any other switch box terminals regardless of which coil I jump to. I have also ruled out bad plugs by testing them.
The question is, are both my switch boxes trash or should I consider stator, flywheel, rectifier or trigger prior to replacing them? I don't want to replace and hope, I want to diagnose and resolve.
The prior owner had this motor serviced by the local Merc dealer this Spring. I also have prior experience with them that makes me a bit shy on their level of service. I'm not about to run back there soon. My diagnostic equipment is limited to a voltmeter/ohmeter, 12V continuity tester and a spark tester along with a bevy of hand tools and gray hairs from past experiences ;>)
I'm patient, but a fishing trip to Cape Cod in a week has put me under the gun to get this fixed ASAP. I'm also retired, so $ is an object. Any help and suggestions would be greatly appreciated.
Thanks!
LC
Thanks!
LC
