UKMike
- Joined
- Apr 15, 2015
- 55
Hi everyone,
I've been told there are some real Gods on here that may be able to help me identify the problem I have and I was hoping one of those Gods would be so kind as to advise?
I have a Mercury Black Max V6 135 serial 0A961186 that has started to have an idle issue. The engine was running fine after changing the following parts but has just started to run rough on idle so that I can't park up or start up and put it in gear without using the throttle first. The engine has all original parts still attached including the self oil mixing devices.
I recently de-winterised her and have changed the following parts:
Lower gear lube
Water pump
Impeller
Poppet Valve
Thermostats
Petrol pipes through out
Increased petrol pipe diameter from front tank to water separator
New water separator filter
New cable ties across the whole engine pipes
New coils
New spark leads
new plugs
New water pressure sender and pipe
New Fuel tank sender unit
New Fuel Pump Diaphragm
The only filter I have not changed this season is the engine fuel filter, that was new at the close of last season and only had 2 weeks usage!
All of the above was done 4 weeks ago and the engine has been running great since but last week I started her and she just stalled with a bit of a splutter. I started her back up again and she starts but the revs go up and down for approximately 10 seconds and then the revs drop and she stalls. If I start her up and increase the revs using the throttle she runs fine but with a little bit of roughness, she seems to be firing on all 6 and she doesn't seem to be pissing unspent fuel out of the carbs or casing cover.
I have sprayed carb cleaner into her while running and I have also used a whole tin of power tune on her, this did improve the running a little bit but I have ended up increasing the idle throttle screw to bring the revs up enough for her to not stall. I don't like doing this as there is something wrong and I have been told that if the idle stabilizer has gone it is possible to pop/crack a piston on WOT and that is not only expensive but it's very dangerous as I only use the boat at sea, normally 12 miles out....
If I take the revs over 1200 I loose all the roughness so I was wondering if it could be the idle jets or something else?
Please could someone advise? I have today purchased a spark tester and a comp tester as I believe that the compression should be around 110-120 per cylinder.
Hope someone will help, I just can't bear the thought of my engine being sick, I love her
Br
UKMike
Lower gear lube
Water pump
Impeller
Poppet Valve
Thermostats
New coils
New spark leads
new plugs
Br
UKMike
