mercury 1988 3 cyl 70 hp
Simmity
Hi Guys,
Hope you guys have some input for me, if so thanks.
The problem I'm having is, when on the water, the boat will do 3500 rpm. On occasion when I throttle down to a low speed, the rpm drops, but, when I throttle up it wont go past 1300 rpm. Then, If I throttle up and down a few times, it goes back to working normal. Happens periodically.
Compression is 120 psi on all 3 cyl. cleaned carbs. Any recommendations?
could it be a bad coil? or timing?
Thanks
flyingscott
3500 rpm is to low. Have you tried pumping the primer ball? Have you done a compression and spark test?
Simmity
sorry, meant 4500 rpm
put, new water pump
yes, I tried pumping the primer ball
I did compression test, 120 psi on all 3 cylinders
changed plugs,
not sure how to do a spark test.
flyingscott
4500 rpm is still to low. To do a spark test buy a cheap spark tester and make sure the spark jumps at least a 1/2 " air gap.
