Mercury 2.2 hp older model will not keep running tried almost everything
fishon71
Motor starts and runs a little, will not get much rpm out of it. She seems the fluctuate in rpm (very low) up & down then dies no mater where the throttle is. I have cleaned the carb and tried with out the carb by spraying mix directly into the intake same result. I replaced the points, condenser, spark plug, flywheel, coil no difference will the replaced parts. These are pretty basic motors and I have repaired a bunch of them but never saw this issue - seems electrical but I don't know. Valves look clean and tight and compression is 110 psi - any ideas?
fishon71
Re: Mercury 2.2 hp older model will not keep running tried almost everything
One thing I did not change because I need to drill out the screws on the plate is the coil under the fly wheel. Is it possible that could be faulty to cause the motor to run erratically? I do not know what else to try.
cr2k
Is the crank shaft loose in the block? Could be bad seal on crankshaft.
fishon71
Nope seems tight to me - I'm lost!
