BassHole559
- Joined
- Aug 28, 2018
- 17
i have a 2002 Mercury XR6 150, S/N 0T591137. I need to know if the gaskets on the front of the powerhead require me to remove the powerhead completely to change them? From the pics I should be able to remove carbs, reed block, and forward crankcase to replace all the gaskets. Specifically the crankcase gasket. I finally got my bogging issue figured out and it IS fuel related. The crankcase has a nice leak at the bottom not allowing enough suction to provide proper fuel delivery through the reeds on the up stroke. There is a healthy amount of oil leaking right under the reed block.
