Hi all,
I have a mercury 4 stroke 20hp about 3 years old and about 150 hrs. I have noticed that when the engine is starting the oil warning lamp is not turning on. I checked its connections and also the oil pressure switch connection both seem fine. Oil level is ok and type to specs etc. I am thinking that either the lamp is faulty , the pressure switch may be remaining open or the cdi not switching or something similar.
1. how can you check the lamp and voltage applied to it when checking. are there any thing i need to have a look at.
many thanks
many thanks
