jakeboomer
- Joined
- Nov 16, 2004
- 19
I have a 1988 mercury 25 horse - short shaft. I bought it a couple months ago and didn't notice cracks in the shaft housing right above the lower unit. I knew the motor seen shallow water, but the compression was great, and there was no water in the lower unit. <br /><br />Last week I hit a submerged dike and bent the prop shaft. Very unlucky. While pulling the lower end, I noticed the cracks were much worse than I thought. One of them goes from the front foot of the housing across to the other side. My question is this. Can this be welded, or does anybody know where to start looking for a used shaft housing? How about locations for used prop shafts? I have a manual, and can be pretty handy with a wrench if needed.<br /><br />Any recommendations would be appreciated. When this happened, I almost tossed the motor and headed out for a new one. The problem is that the motor runs so well. I rebuilt the carb and it starts in one pull every time. It has excellent compression to boot. Thanks again.
