Hi All, First post, but been lurker for a few months and found eveything I need with search function so far.
I'm having a hardtime with my engine, maybe somebody can help me figure out what I'm missing or didn't check. I just bought this boat last fall and only took it out once, it was staving for fuel.
The motor starts up just find and idles great. I give it some throttle and it starts to sputter and stall. I can feather the throttle, and it will almost get to 3/4 throttle before it stalls. If I WOT from idle it stalls. The motor will start right back up everytime after it stalls. If i put my hand over the air intake and give it throttle, it runs better and can almost get it to WOT.
Thanks to older posts here, I was able to check and replace if needed the following.
replace fuel tank (put fresh gas in)
replace fuel line / bulb from tank to motor.
replace fuel filter
replaced the fuel pump (brand new, not rebuilt)
replace spark plugs
REBUILD CARB 4 times with rebuild kit. The final time i rebuilt it, i let it soak in Sea foam overnight, sprayed it with carb cleaner and blew out with air. I made certain every hole and passage was free. I really, really took my time, the high speed jet is clear and so are the other jets. I also put a new boot over accelerator pump(old one had a tear) and new spring.
I did a compression test on both cylinders. 110-115 on both.
The motor specs are:
1999 Mercury 25 hp Big foot 4 -stroke Serial number #0G735589 model 1-f25311ud
I'm at a lost, I don't know what else to try. It seems like its still starving for fuel, since if I put my hand over intake it runs better for a bit and can rev it up (wot). I did not check electrical.
Thank you,
replace fuel filter
replace spark plugs
Thank you,
