mark1961
Ensign
- Joined
- Apr 30, 2007
- 940
I have question for the knowledgable folk here......my friend has a 2002 model 25ML Mercury motor, last time out he went to select reverse with no luck and ever since the situation has been the same, no reverse, selects forward gear fine. This motor has the two shift cables coming from the tiller arm pivot. They both appear to be in good condition and working but the reverse side comes to stop before selecting reverse. The tilt lock was activated, so it should be going in reverse, tried all the obvious stuff too like rotating the prop with no joy. Any ideas what could be causing his problem?
Thanks in advance for any help you can give.
