dobrosailor
- Joined
- Nov 14, 2015
- 3
Went out on a limb and spent $90 on a 1977 Mercury 4.5 long shaft for my Catalina 22 from the original owner. He only used it on Sundays couple times a year ;o) but it really appears to have very low hours and to have been very well maintained. Last memorial day he was fishing and "it stopped" and never started again. His mechanic sold him a new electronic module (potted orange module with two posts and three screws) for $134 which he tried to install then gave up and put the whole thing on Craigslist.
I found a clean motor with good compression but very crusty wires so I rewired the crusty ones and installed the new module, luckily he took photos before he disassembled the motor so I "think" I have it wired correctly but my old shool vintage car years found connecting the condensor to the positive terminal of the coil a little disconcerting, usually they connect to the points on the neg side but I cannot find a wiring diagram on the internet and I have no experience with systems lacking a battery. Still no spark (shut off button disconnected from coil). I came across this post from 2003.
http://forums.iboats.com/forum/engi...s/481843-4-5-mercury-still-spark-intermittant
which has some great data sheets on testing stators, coils, condensor and the electronic module but it is not clear just how to execute the tests, in place or disconnected? For instance, it shows the coil with a ground which I do not see on my two post system, one post goes to the points which are funky but seem to work fine in an ohm test, dressed them up a bit. I am very comfortable with a Volt Ohm meter, any guidance on how to test each module to work to the offending culprit would be very appreciated.
