I have a 2004 Mercury 50 4 stroke EFI with less the 5 hours on it. If I idle for more then 2-3 minutes the overheat warning horns sounds off. I notice that the water tell is not squirting out a steady stream of water either at idle either. If I shift into gear and get the rpms up a little then the overheat alarm goes off and the water tell has a steady stream of water again. I was told this is normal for mercury 4 strokes but it does not seem normal to me. Anyone has suggestion or comments on this? Thanks
