I inherited a 1994 24' Aqua Patio Pontoon boat from my father. The boat runs fine going slow to medium throttle. When I go full throttle or anything past 4200 rpms, after about 30 seconds I get a constant beep that won't stop unless I bring the throttle back down to idle or very slow. Running slow around the late for hours I have no problems. Had it out in the 100 degree weather running medium speed and never had an alarm. Only going fast.
Boat is peeing strong the whole time. I'm told my dad had the water pump replaced last year. I'm also told he had the same problem but never went fast so he didn't worry about it.
I have read online that one theory could be cavitation causing the boat to not get enought water when going fast. The pontoon does have a steel V shield in front of the motor. I can't say for sure if this motor is original with boat. Is it possible that when going fast it rides higher and is not getting enough water some how?
Don't know if I shold try to replace water pump again. Maybe replace thermostat ( but I would think if its bad it would overheated at med speed) or maybe this cavitation has some merit.
Thoughts? Any tests I can do to help determine problem?
Thanks much
Thanks much
