Re: Mercury 402 Lower Unit Shift Rod Installation
Been though this ordeal a few years ago. Take pictures when you take it apart to help you remember how to put it together.
1. With lower unit off, place control lever in forward gear. The angled parts of the square gear shaft in the upper unit should be in line with the boat/engine. If not, adjust your shift linkage so it lines up correctly. When shifting the shift lever, the shift shaft should rotate 45-degrees for each shift (i.e 45-degrees from forward to neutral, 45-degrees from neutral to reverse).
2. Get a pair of vice grips and turn the gear shaft in the lower unit to forward. Agan the angled parts of the square gear shaft should be in line withe the forward/backward direction of the lower unit. The prop should free spin in the reverse direction and turn the main driveshaft in the forward direction.
3. Test by turning the gear shaft in the lower unit 45-degrees counter clockwise (when looking from the top). It should go into neutral, and the prop should free spin in both the forward and reverse direction
4. Turn the gear shaft in the lower unit another 45-degrees counter clockwise, it should go into reverse, and the prop should free-spin in the forward direction, and turn the drive shaft in the reverse direction.
5. Turn the gear shaft in the lower unit back to forward (90-degrees clockwise).
6. Make sure the reverse lock cam in in the correct orientation, see the picture (note, it's in forward). The lower edge of the cam should be in the "forward" position, and the high edge of the cam should be in the starboard position.
7. Make sure when you reattach the lower unit that lower and upper shift shafts line up correctly.
