Hi guys i have installed a new tacho and its not working. The old one wasnt working as well.
It's on the 6p setting
I have changed the rectifier
- the tach signal from the rectifier is to the gauge has continuity
- the ignition power is getting to the gauge
- the wire from the ground on the gauge has continuity to the negative sode of the battery.
There is one issue though, when i connect to the tach signal wire to negative on the battery it shows a continuity value of 480, what does this mean?
Any suggestions as to why its not working.
