Looking for advise and tips to remove shift linkage from swivel/pivot tube on my 2006 3cyl 40hp 4 stroke. Engine runs, shifts and operates flawlessly but has terribly stiff steering. The stiff steering is fine for boating around, but when I need control, like when at busy ramps, the stiff and difficult to maneuver steering is cumbersome and potentially dangerous.
I am familiar with basic outboard repair, and tinker with all manner of machines but would like to pick the brains of somebody with experience with this before I end up breaking something on my new to me boat. Note: I work in aviation and may not use correct terminology so please go easy if i provide incorrect nomenclature to components and piece parts.
Recently I bought this 2012 mako pro skiff 16 for fishing intercoastal waterways. The boat appeared to be well taken care of and used exclusively in fresh water until I purchased it. Everything seemed to be in good working order, but I neglected to take a look at steering while giving a thorough look at everything else. Now its my problem and i need to find a solution.
To attempt to remedy the stiff steering, I have disconnected the steering cable from the drag link and the steering wheel can be turned easily with 1 finger, so thats not the problem. The stiffness without question is in the swivel bracket/pivot tube. I first attempted to grease the swivel bracket zerk fitting (1) and had a fair amount of different types of grease flowing from the top of the swivel bracket tube, nothing on the bottom. after a full tube of grease, a consistent color of the new grease was coming from the top, non on the bottom, steering still stiff. I attempted to heat the swivel tube to break up any old grease that may be packed between the bushings and pivot tube and swivel bracket, that didn't have much effect either. I bought a zerk rejuvinator tool and pushed a bunch of penetrating oil in until it started to flow from the top of the swivel bracket, still not much difference.
So after 2 weeks of fiddling with this thing, a good 20 hours easy, i'd say the steering is a little better, but when you let it sit overnight it is initially stiff then starts to loosen again but still requiring a lot of effort to turn.
Long story short, I have decided to tear apart the swivel tube, clean everything and replace the bushings. Ive watched a bunch of videos and looked at countless parts breakdowns and have a decent idea of what all is involved. However, I am not sure how to remove the shift tube from the swivel bracket. To me it looks like the power head has to be removed in order to remove the shift tube vertically up. I don't want to do anything too invasive and seeking advise before I rip it apart. Any advise would be greatly appreciated.
