Chris Cole
- Joined
- Apr 23, 2007
- 45
Hello forum,
I am new to this forum, I have been reading threads to try to fix my motor. I haven't had any luck yet. I hope someone can help me? Here goes.
The problem started after I ran my motor hot. My thermostat got clogged with duck weed. It wouldn't allow water to circulate. I knew my motor wasn't peeing, but ran my motor anyway. After this experience I can't seem to go above about 3000 RPM's, sounds like Iam running on two cylinders. Also, sometimes the motor Idle's well, other times it runs real rough, I have to rev it just to keep it running. As a result of running my motor hot my thermostat melted. I replaced the thermostat, but that hasn't fixed the problem. I have checked the compression in my cylinders after the incident. The readings I got were right about 100 (Cold) in all three cylinders, so that is not the problem. I also had a leaky fuel line connector, that I thought would cause the WOT problem, I changed the fuel line connector; no change, still 3000 RPM's. I put new spark plugs in and tested the spark last night and found that it was intermitent. It was sparking some times, other times it wasn't. When I put a timing light on it, the light would blink sometimes, and other times it wouldn't.
REV LIMITER:I tried disconnecting the rev limiter (Black/Yellow Wire)? I also disconnected all wires from the rev limiter and the motor still ran, is this right? ( I have four wires coming out of the rev limiter, Black/Yellow which connects into two black yellow wires. Purple, which connects into another purple that is not being used. Brown, which connects into two Browns. Black, which is for ground.
Trigger: I did an Ohm test for the trigger there are four wires coming from the trigger. Purple,White,Brown,Black. I tested resistance across all of these connections and I never got a reading (Nada). Today I ran the motor a little bit with ear muffs, and after having run the motor I tested the trigger. I had 10 or 11 MegaOhms from Black to Black coming out of the trigger?
Stator: I did an Ohm test for the Stator (600-700 Ohms). 4 Wires coming from the stator. Green/White, which connects into two Green Whites. White/Green, which connects into one White Green. White with Blue Stripe, Which connects into another White with Blue Stripe that is not being used. Black goes to ground. Last night the Ohm test passed with flying colors, this morning I could not get a reading????
There are not too many electrical components on my engine; trigger,stator,coils. I am baffled, should I rip my flywheel off and replace my trigger? I feel like that is a guess. Please Help.
