I recently got my first boat and after taking it out the first time and it having a slight miss I started going over everything on it. It has a 1985 Mercury 50 on it. I checked the compression on the cylinders and they have good even pressure. I took the carbs off and cleaned them ect. The motor runs great now and Im about ready to start hitting the water.
I decided I would unbolt the motor and clean up the transom and replace the bolts. There are a total of 8 mounting holes but there were only 4 being used. Both bottom bolts on the motor mount and the top bolt on the left trim mount and the bottom bolt on the right trim mount. And the 2 clamps on top
These are the only places that have holes in transom for bolts so I assume its been this way forever but want to make sure it is ok. Also the bolts were carriage bolts which worked great but didnt know if I should use regular bolts. Sorry if these terms are incorrect I am new to working on boats. I can post pictures in the morning.
