Hi i have been searching for answer all over google but could only find one similar problem like i have but the forum is closed and i cant contact the guy.
My motor start really well everytime but no hesitation go to 5800 rpm no prob but when i stop to troll with the electric motor when i try to restart i have to situation it can run without a itch or it will start like a charm but will start to run rough within 1 sec like its starving for gas and die. it can last like that for 5-15 min than it start without a problem for the rest of the day or do it again.
I tried to pump my primer bulb when it started to run rough without any change.
I changed both fuel filter and cleaned the vst
Did my spring tune up changed plug and oil etc
My next move is to rebuild the mecanical fuel pump.
The guy changed i have saw on the closed forum changed is idle selenoid without succes.
Do any of you guys have a clue ?
Thanks
Thanks
