Nandy
- Joined
- Apr 10, 2004
- 2,145
Mercury 500 / 50 H.P. Four Cylinders<br />Motor s/n 2479050 Year prob. 1968<br />Here I go, working motor and I have to try to make it work better, Right???? Well, I found that the cables jackets of the internal harnes for this motor are comming appart. This was causing me problems trying to start the problem as it was short the starting cable. I disconnected the harner but forgot to take the secondary cables I had for the bateries. That meant that some cables where still alive. One of those cables touched the orange cable that goes to the blue connector in the switch box. Now I have no spark on the plugs.<br />I tested the distributor coils and the resistance is ok. However the book does not shows how to test the switch box. I check them and only the blue terminal is grounded. There is no continuity beetween any other terminal. Can anybody check if their working motor also shows the blue terminal grounded? I really doubt that will be the case, this terminal is grounded to shut off the motor. <br />Anybody has a cheap used switch box for sale?<br />Thanks...
