Britcheflee
- Joined
- Oct 4, 2010
- 79
Hello,
I picked up a 1959 Dorsett Catalina with a mercury 55A motor - the motor is now on a stand and unfortunately it will not turn over - I dropped the lower unit and that is not seized up - I am fairly sure it has the rings rusted to the cylinder walls as it sat for some 7 years outside - what gives me a bit of hope is that when I picked up the boat the motor pull cord was all the way extended out - the recoil was gummed up so it did not recoil so they just left it - this indicates to me that there was at least some time in the past where someone was able to pull the cord and turn the motor over (wishing for a bit of good luck here) - anyway, I have had the thing soaking for 2 days now with mmo, pb blaster and any other spray/lube I can find in there - still will not budge - any other suggestions? I was told to remove the head and use block of wood and mallet to tap piston heads to free up too - what are your thoughts on that and how difficult is removing head/replacing?
Any suggestions welcome!!!!
Lee
Lee
