brokensword
- Joined
- Mar 15, 2011
- 6
Okay so I just changed the carbs and fuel pump on my 90hp blueband because the engine was difficult to start, dripped fuel from 2 carbs when I did manage to start and would not provide any sort of power.
A marine mechanic recently told me that the problem was the reed valves, probably on the bottom carb as the top tow "looked okay" Do you think this is correct?
So far, after changing the carbs and fuel pump around I have only been able to start the engine once, after great difficulty. The engine seemed to be unable to keep a constant idle speed. This could just be that the carbs are not set up correctly right?
Also, I know that the reed valves are inside the engine, but are they difficult to change?
Sorry about all of the questions, I am new to this and struggling with this
