My little Merc 60 (3 cyl 1994) outboard acts like it's running out of gas. It starts fine and takes off great, then starts choking down as if starved for gas. You can shut down to a idle and let it idle for a minute and then hit it again and it takes off normally, then starts choking down again. I've changed the filter and it didn't help. This morning I took the gas tank off and cleaned it out. Not very dirty. I put the gas back into the tank by filtering it thru a piece of felt material. Checked the pump bulb the best I know how (disconnected and blew thru, pumps up and holds, squirts when pumped and push in on release valve at engine end) and it looks ok to me. What else can/do I need to check???? Thanks for your help.
