Mercury 60 HP Outboard
rickdb1boat
Re: Mercury 60 HP Outboard
I believe it is. Measure the gearcase opening where the prop sits. What size prop are you running. That will tell the story. Post back with the info..
nngilbert
The Diameter of the prop is 12.5 inches (I measured the radius to be 6.25 inches). I found two numbers on the prop.<br /><br />49-42738 A10 8P<br /><br />LP18014B<br /><br />The exhaust is thru the prop. Can you also tell me the pitch of the prop?
rickdb1boat
If the diameter of the prop is 12.5 inches, it's a bigfoot.
