Re: Mercury 650 and 850 Lower Units Interchangeable?
The 13ft Allison with 150xs inline powerhead on 1986 midsection. It has had the following: bored .020 oversize,enlarged/modified boost port on block and piston,modified transfer port covers,thinned and enlarged reed blocks,modified megaphone exhaust tube, old style 150 carbs coverted to primer,1980 225hp spark advance box (26?), Xr4 1:78:1 lower unit and cut down 22 pitch big ear chopper prop and about 2 years work on engine. On good water 3-4 inch chop it will turn 6600rpm at about 66 mph. And below is pictures of a EFI inline in the work by a fellow iBoater
. The lil inlines dont start making power and torque till about 2000 rpm and the 2:1 is not to noticable on a light hull but a ole sled trihull it shows up big time. Long story shorted,young fellow up road had a fabuglas 17 runabout, found a ole 850 rigged it out and kept bugging me that it was low on power and had hard time puller a skier up but ran great at WOT,we checked,carbs,linkage,etc,etc then ratio and was 2:1,loaned him a 2:3:1 unit and with same 17 pitch was huge difference.
