Basically where my block meets with the outboards aluminium body, Basically where the block is bolted on the side where the spark plugs are.. There is water leaking through where the block makes contact with the shaft.<br /><br />Basically could this be a seal problem and it would just need me removing the block and replacing the seal, or could it be because of corrosion thanks to previous owners not flushing?<br /><br />Also if i pull the block, is it mandatory to remove the carbys and fuel pumps or can they stay on? <br /><br />Motor is a 1970 650 Thunderbolt 65hp, 4 cylinder.<br /><br />Thanks i will include a picture or where it is leaking as soon as I get back from school<br /><br />
