2 cylinders don't fire really. When they do its occasionally like the motor is sneezing. Theres hjoles in hte outboard body and water is coming into the engine bay and leaking out 3 holes out of the sides. My mechanic said, because there isn't enough water pressure the third and fourth cylinders (the 2 bottom ones) are firing whenever they get enough pressure aka at high rpm's but when at lower rpm's they fire hardly ever and give a sneezing like punch and a puff of smoke comes out of the exuast and the whole motor jolts to the right or left. He is a trusted mechanic but i hvae heard this is relating to other things.. its a Mercury 1970 Thunderbolt 650cc 65hp. One of the most stylish "older" engines i have ever seen (with the chrome etc.) and it really suits my "older" boat
<br /><br />I had a feeling it was the carbs but then again petrol wouldn't really build up and then fire causing the jolting. <br /><br />To fix the holes up to he has to remove the entire engine block and everything then seal the screws where the lower unit water shoots up through.<br /><br />Its been a medium priced lesson for me but i will konw my **** for hte next motor/boat i buy just by starting it (mechanic friend taught me heaps recently good mate of mine)<br /><br />anyway g'day/g'night whatever it is overthere
and a hello from the land downunder
