Michawilden
- Joined
- Apr 4, 2015
- 153
I got a 80's 7.5 hp sail power mercury. I bought it for a couple of euro's ( I live in the Netherlands). Previous owner bought it with the boat and never used it but has been told that the gears where not working properly. I started the engine and it worked great, not pumping water but i didn't expect that anyway. The problem is that the motor sticks in first gear. I lowered the LU to inspect it. Expecting a mis allignment. However, when I dropped it, the shift cam stuck in the mid section in stead of the lower unit. It is obviously broken.
Now I doubt what I should do with it. I hoped you guys can halp me with a decision. Can I try to retrieve the other end by removing the shift rod bearing? Or do I have to dismantle the complete unit? I suspect that the other end of the shift rod still sticks in the shift cam and won't just fall out of the shift cam. If an end sticks out of the shift cam, is it even possible to get the cam out when I completely dismantle the LU?
The gear case sounds good, no weird bearing noises and no visually abnormalities. A second hand gear case costs about 75 euro's and this doesn't guarantee a proper working LU. What should I do? I got most of the tools to get the lower unit apart, I will have to manufacture a tool to remove the ring whish keeps it al in place. But is it al worth the time?
