Mercury 7.5 water pump melt-down . . .
tpenfield
Last year the water pump on my 1969 Merc 7-1/2 hp crapped out (S/N 26346XX). No big deal, I figured, I'll get a new impeller. I took the lower unit off yesterday and went about disassembling the water pump.
the thing looked more like a melt-down than just a simple failure of the impeller. It seemed that the impeller and the pump housing had melted a bit.
I have new parts on order for the pump, BUT . . . .
In the process of getting the old impeller out, it seems that the bronze/brass hub of the impeller has become 'fused' with the drive shaft.
IMG_2845.JPG .
I cannot seem to get the 'hub' (which look like a hex nut in the picture) to slide up off of the drive shaft like it is supposed to. FWIW - this driveshaft is not original to the motor - it is a stainless steel shaft from a 1980 version of the Merc 7.5
Just wondering if anyone has any ideas, tips, tricks to get the hub off. :noidea: I can see the 'pin' that acts like a key to turn the impeller with the shaft, but the hub itself seems to be one with the shaft . . . probably because of the apparent amount of heat during the 'melt-down' :noidea:
TIA for any thoughts on this. I don't want to try to cut it, fearing that I may cut into the driveshaft a wee bit.
I've been using the Johnson 4.5 in the meantime, but to add insult to injury, the Johnson decided to crap out yesterday :rolleyes: Me thinks it is a fuel flow problem, but that is a story for another time.
use a dremel to split the brass hub
tpenfield
Quick update . . .
I can't seem to find my dremel tool . . . so maybe I'll just be careful and use a small file to cut into the hub and then split it before I cut all the way through.
Still waiting on the water pump parts, but they should arrive soon. Meanwhile, I got the Johnson 4.5 hp running again. Amazing what a little bit of acetone and seafoam directly down the fuel line can do :D
Additionally, the Admiral's aunt mentioned that she has an old outboard motor (3 hp of unknown brand/model) that I can have. So, for the price of a courtesy dinner, I'll have 3 outboards. I believe that outboard is about 30 years old, and was only used for 1 season, back in the late 1980's. Should be interesting to see if it 'turns' and if it can be made functional (again)
I figure with 3 outboards of 50, 40, and now 30 years of age, I ought to be able to keep at least one of them running :rolleyes:
nola mike
Looks like it would be tough to get a Dremel in there. Does that nut need to come off to remove the housing? Or might need to sacrifice that as well. Guessing there's a woodruff key there, so you can't remove it by twisting. BTW, number of small outboards doesn't matter. I keep buying them when I find a good deal, but I haven't found the time to get any working (2.2hp Merc, 2.Something gamefisher, 2 electrics, 5hp Ted Williams, 2 hp Johnson --haven't even attempted to start the latter 2 :)
tpenfield
Yes, the hub (nut) has to come off. I'll figure something out.
Meanwhile, the parts for a new water pump arrived yesterday. Also, I picked up the motor that the Admiral's Aunt is giving us . . .
A new (unused) 1990 Yamaha 3 HP (model 3D) . . . The Uncle bought it in 1990 and never got the chance to use it. It has been sitting in their basement for 30 years :eek: !!!
tpenfield
Correction . . . I think the Yamaha is a Model 3SD :noidea:
tpenfield
The Yamaha after sitting for 30 years works !!! :)
I ran it for about 2 hours tonight with a heavy dose of oil and seafoam in the fuel to clean out the carb and get some break-in done.
This will take the pressure off to fix the Mercury.
nola mike
Lmk when want to get rid of it, I'll pick it up when I visit my dad in mashpee ;)
tpenfield
Oh what luck . . . as I was working on removing the remains of the water pump impeller, I noticed gear lube coming out from around the propeller . . .
Looks like I'll be re-doing the lower unit seals too :facepalm:
tpenfield
Quick update . . .
I have not had much time to fiddle with the Mercury 7.5 . . . Today I was able to get the impeller hub 'sliced' open with a sharp chisel and managed to get the hub and water pump housing off of the drive shaft.
Not much left and part of the impeller was fused to the SS 'cup' of the pump. So, it is good I got all new parts.
One thing that I did not realize is that the new housing part came with the SS cup and the lower seal . . . could have save a few bucks since I bought those parts too. :facepalm:
I just have to order the prop shaft seal and the shift shaft seal, so all seals will be new.
I have to take the retaining ring/nut off the lower unit hub, and for some reason, I cannot find the special tool that I had when I replaced the seals about 5 years ago. :rolleyes:
I might just order another one . . . often I find that easier than searching for it. :)
garbageguy
...I might just order another one . . . often I find that easier than searching for it. :)
I hate it when that happens. Interestingly, when the Admiral and I were meeting another couple of our "vintage" last night, the woman was talking to me about her hubby doing that as well - Good to know I'm not the only one.
Nice score on the older, unused, Yammy
tpenfield
OOOPPPS . . . I did it again. Melted the impeller/pump. . . again.
As i was untying the line for the dinghy at the bow, the prop/LU of the Merc came out of the water for a few seconds . . . that was enough to kill the impeller and then the water pump did another melt down.
It seems that the impellers on these things have a low tolerance for lack of water supply . . . more so than the Yammy's I've had.
Looks like I'll be ordering another impeller & water pump parts. :unsure::rolleyes::cautious:
Rub your hands dry and you feel the heat.-----Running one of those or any impeller dry for 10 /15 seconds just kills them.-----Found 2 impellers burned on 70 HP motors last year.----Many novice boat owners learning the facts these days !!
tpenfield
New parts are on order . . .
Note to self . . . turn off the motor if going to the bow of the dinghy :rolleyes:
tpenfield
With a burst of motivation, I fixed (replaced) the water pump on the Mercury and got it running again. I had to run some barnacle buster through the cooling system and blow some air through it as well in order to get a decent flow of water.
I think the cooling system could use a heavier dose of barnacle buster, but that can be a Fall put-away project.
It seems like we are supposed to have a windy day on Sunday . . . something about a hurricane :unsure:. I saw , a guy tending the line on his dinghy from the bow while the motor was running. I think he toasted the impeller, just like I did.
Lots of folks taking their boats out. Based on the forecasted track of the storm we will have off shore breeze and a flat ocean.
