Moserkr
Chief Officer + Starmada Splash Of The Year 2021
- Joined
- Nov 23, 2020
- 871
Hey everyone,
After rebuilding my boat, I recently put a new motor on her. I started with a standard propeller on the recommendation from the shop where it was installed. Id say they guessed pretty well. I will list propeller stats below. My goal is more stern lift, better handling, and mid range cruise - Id like to move to a 4-blade prop. Id like to stay between 5000-5500 rpm. Boat is used for cruising, towing a tube, and trolling for fish. We usually boat at high elevation so 4-6000’ is normal. The current prop can be used at sea level as it hits my max WOT operating range.
Current Propeller and Data
Mercury Black Max 3-blade Aluminum prop
15 pitch
13.75” diameter
WOT operating range 4500-5500 rpm
Heavy load = 5 ppl + gear
Average load = 3 ppl + gear
WOT 5200 rpm average load @ 5000’ elevation, trim full down, 32 mph
WOT 5100 rpm heavy load @ 5000’ elevation, trim up slightly, 31 mph
WOT 5000 rpm heavy load @ 5000’ elevation, trim full down, 30 mph
WOT 5500 rpm average load @ sea level, trim full down, 33 mph
Motor currently sits on the 2nd hole so my cav plate is slightly (1”) above the keel.
I think thats all the data that should be listed. Id like to stick with an aluminum prop for now, but once I get a 4-blade AL dialed in, then switch over to SS.
So my thought is I could possibly move down a pitch or 2 to a 13 or 14 pitch. Seems like those are geared more towards pontoons though. Another thought is stick with the 15 pitch but in 4-blade, then eventually add a manual jack plate with setback. Would like to stay in the mercury family of propellers so all things stay equal in general. Thanks in advance for any thoughts and suggestions.
15 pitch
13.75” diameter
