Big Pete
- Joined
- Aug 12, 2009
- 192
Today was an absolute belter , 35c and the sea calm and flat in short brilliant boating weather thumbsup.gif
So me and Mrs BP get the drinks ready and toodle down to the Marina..
I hop on the boat remove the cover , prime the fuel,switch on the Batteries and drop the engine in the water ..
I place the key in the ignition give it a couple of clicks on the electric choke and she spins over ,
She spins and doesnt fire so i reprime the bulb on the fuel check all is on etc , give it another 5 clicks on the fuel choke thingy , and
I have the idle on full up as how i normally start it and last time and normally she just bursts into life ,
i give it a few more choke injections and she bursts into life
runs with full idle up and then just slowly dies .. rechoked again nothing strong smell of petrol so i assume i flooded it ,so leave it to settle try again with NO choking nothing..
Go back through entire start up sequence again giving it 5 bursts on the auto electric choke thingy and once again she bursts into a smokey running mode , the smoke dies and then she just slows down as if its running out of fuel again ..
yes it has fuel indeed you can see it dripping from around the Carbs ,
Now the last time the engine was run was 6 weeks ago and it poodled around the harbour fine , since then its sat tilted out the water in the blazing heat we have had for last month or so..
I have a hunch maybe fuel dried out in the carbs and needles stuck perhaps or something ?
SO whats the verdict ? any ideas or thoughts ?
The fuel is old over 12 months which i intended to run out and refill today , but obviously that went out the window...
