Hi
I have a Mercury 80Hp Thunderbolt (1978 or 1979)
Everything runs great when I shift to foward, but I can't get it to reverse without killing and locking the engine.
When I put it in reverse, the propeller start to spin a little then the engine dies. The shift cable can't move anymore (foward or neutral) It is stuck there. The engine won't crank with the starter either. I need to go to the propeller and spin it by hand until it makes a "clic" and get back to neutral.
When I try it on the trailer with the muff, it shifts easily foward and reverse. When I get the boat to the water, the problem happen.
I've dropped the lower unit and spins the input shaft by hand while moving the shift arm. Once again, everything is fine.
It also shifts to reverse if I put the fast idle lever up to about 1200 RPM, but it's way to high for a smooth engagement.
Anyone ever encounter this problem?
Thanks
Thanks
