sandhopper2
- Joined
- Oct 9, 2013
- 105
Is there a kit or parts for a 1975 85 hp 4 cylindar motor for power tilt ? motor SN number is 4096602
Thanks Larry
Thanks Larry
I had TT on my '85 so they exist. This used the original design of the twin cylinders outside the clamp brackets where they originally had shock absorbers.
Doesn't directly help to solve your problem but at least you know they cam as OEM equipment from the dealer on a new engine.
I had a '72 Johnson 125 with no trim or tilt. Back then they only offered tilt. After several years I wanted some tilt. I bummed around and found a dealer who had been in business for a long time and sure enough he had a new one, very dusty and I was in business. You may find the same for your engine if you have a dealer handy.
Mark
