I ran the outboard on the used boat I bought for the first time this past weekend. See signature for specs. After getting it started it idled good and ran great for the first 15 minutes. I could go from idle to WOT with no hesitation and no problem. Then, it got to where it would idle fine and would run up to about 1/2 throttle just fine, but beyond that it sounded as if it was either starved for fuel or flooding out. I checked fuel lines and bulb and couldn't find any visible signs of problems. A friend of mine suggested replacing spark plugs and wires for multiple reasons. He says if I don't know when they were replaced last, it probably needs it. Plus, he says when spark plugs fail, sometimes they only show signs of problems once hot. Does this sound reasonable? Any other things to check?<br /><br />Also, concerning replacement spark plugs. The reference I found online lists Champion plugs, p/n: 5898. However, the parts store cross referenced that number to a Champion L76V. Upon further research I found that the 5898 plugs are designed for CDI ignition systems where the points have been replaced with electric circuitry, while the L76V plugs are just regular resistor plugs. It says not to use a regular resistor plug on engines with CDI. Does my outboard have CDI or points? Does anyone know from the service manual the exact plug that it calls for?<br /><br />Thanks for all the help.
