Re: Mercury 850 sensors
Moody, The inlines do indeed have low water pressure, especially at idle. If you have a threaded plug on the head water jacket, I would use it. If not teeing into the tell tale is the only other option. Use a brass tee that threads into the block. One side of the tee is the pressure fitting the other side is the elbow fo the the tell tale hose. It will work, I have done it.
