katsandsuds
- Joined
- Sep 23, 2008
- 6
I have a 75 model merc 850 (ser #4297882) that has an intermitant starting problem. When I turn the key or push in for choke, nothing happens in either mode. If I turn the key over several times, it will begin working again correctly, but the problem has gotten worse since the condition began last time out. I have pulled the controls apart to verify the Neutral interlock switch is adjusted and working properly and it is. I have pulled the man-overboard safety switch (not sure proper name) gnd off to make sure that was not the problem, and I don't have, or can't find, a mercury tilt safety switch off the distributor side of the switch box that is shown in the wiring diagram. The controls are not original, one on the boat now is PN 881170A3, and inside the controls, the wires have different colors from the original wiring diagram so it is making it more difficult to troubleshoot.
I believe the switch is going bad is the problem, but not sure. My questions are:
Is there anything other then the key switch that links the starter solenoid ckt and the choke solenoid ckt and could cause both ckt's to be disabled at the same time? The wiring diagram says there is not, but would like to check with you guys, not sure if there is any type of interlocks or not that is not obvious on the diagram. I have checked the Internal to External harness connector and it is spotless. If there is nothing else linking them together other then the switch and the plug, then it has to be the switch. Also, with the lever out of neutral, the choke should still work, just not the starter ckt.
Secondly, does anyone have a wiring diagram for the controls themselves so I can make sure I understand the color coding in the new controls.
Thanks in advance for your help.
