Mercury 850 XS
damianfishy
Hello all, I'm going to collect this engine in a few days time, just wanted to know if anyone has any information on it
Such as what the XS means and the HP at the prop, the title of listing i'm buying it from mentions 75hp 850 xs wouldn't it be 85hp?
Also if anyone could give me a serial number for an impeller for this engine would be appreciated
Thanks
Faztbullet
Re: Mercury 850 XS
If its a original XS it will have the water pickups under skeg and no side inlets and makes about 80 hp at prop and is a 1976-79 range and will have ADI ignition.
damianfishy
Re: Mercury 850 XS
Thank you for the information, Does anyone possible have a part number or a link for an impeller for this model, cheers
damianfishy
Re: Mercury 850 XS
Thanks for the information, picked the engine up today and is on a pallet in my garden now, Was wondering does anyone know the weight of the motor? Actual weight it has power trim, would be appreciated
Thanks
emckelvy
Re: Mercury 850 XS
A longshaft 850 weighs-in about 252 lbs; I can't recall if that was with power trim. The PT&T cylinders and brackets would add maybe 10-15 lb at most.
If you're thinking what's a good way to pick it up, one of these screwed into the center of the flywheel is probably the most secure/safe way of doing so:
Mercury Mariner Flywheel Puller 91 849154T1 Lift Ring 91 90455 1 Lifting Eye | eBay
HTH............ed
p.s. congrats on your purchase of this rare motor!
