Hello kind folks. I redid my water pump and impeller and reattached the lower unit. I followed the Merc service manual as much as i could.
It said to put the gears in forward when disassembling.
Before reassembling it said to shift the unit into Neutral. I couldn't figure out how to do this without the unit attached. i tried for a while and then decided to see if i could attach it as is(while in gear)
I carefully aligned the splines of the shifter while my friend gently shifted back from forward into neutral. I then pushed the driveshaft until it caught, while spinning the crank.
Everything seemed to line up and bolted without too much resistance. Once connected though I wasn't able to shift the motor into neutral.
My questions are..How do i shift into neutral when the unit if off?
DO i need to have it in neutral while reattaching the unit correctly?
Any obvious problems and/or solutions?
Thanks so much for your time.
Ian
Ian
