jim_in_day
- Joined
- Aug 29, 2005
- 175
Hi everyone! Well, we have been working on the 9.8 for a while now, installed new coils to get spark, We.ve been thru the carb 3 times now, with a fine tooth comb, cleaner, cleaner, air, kit. We rebuilt the fuel pump. It will not start until you either pour fuel down the carb throat, or manually advance the throttle to about half throttle and hold it there while you pull your arm off. Once it starts, it will restart on the first pull. Let it get cold (ie sit for a day or so) you have to start the procedure all over again. It responds to adjusting the idle air/fuel mixture screw, and when we get the sweet spot it seems to idle just fine for a while, then the low speed idle seems to quit working. The customer is getting tired of it not working, but we just cannot make it cold start reliably. What is the secret? This is a CD ignition not points motor serial number 5640028
