specialTEXAS141
- Joined
- Mar 29, 2024
- 4
Hi.. i have a mercury 9.8 and i changed the impeller and i know for a fact it pumps water.. because when i turn the engine over with a drill with the spark plugs removed water is seen from the tale.. but when engine is running i get fumes and very little water.
After testing to make sure there isn’t a leak in the water tube or pump housing i found a leak that almost seems designed.
In the picture below is where I believe exhaust back pressure is escaping into the cooling system. (The picture is taken from where the lower end would be.. looking up.
