Bluestream
- Joined
- Sep 28, 2010
- 296
I have a 89 Merc 9.9 (not a Yamaha) that only starts when cold and runs for about 30 seconds and stalls. after that it will fire for 3-4 seconds and stalls each time. Plugs are wet when removed and fuel shows in water, so it is running rich.
Compression good at 105 PSI in both
New plugs installed, both getting good spark. (has aftermarket CDI box)
Carb (has carb from an 8HP) was taken apart and was clean. Fuel needle/seat held pressure for 10 min
Reeds appeared to be good and sealed tight
Float was good and main jet clean
Low speed jet at 11/4 turns out
At wits end, any other ideas? Its obviously getting too much fuel, but why?
