Hi
My oil injected 2 stroke Mercury 90 ELPTO always slow drip leaks oil when tilted up fully up, if the oil injection tank is filled above a certain level (see photo).
I cant physically see any drip however can see the puddle in the boats transom area.
When getting it serviced the mechanics say its a common problem with this model and they have replaced the oil fill cap and seal multiple times, which has not worked.
Just wondering if anyone knows away to stop the leak as only filling it to a third means I need to top it up quite regularly.
The only solution I could think of is maybe putting a hose clamp around the the out side of the lid to try squeeze a better seal.
Any advice appreciated
Thanks
Josh
Thanks
Josh
