2001 Mercury 90hp won't crank... Got full battery 12.7 upon turning the switch my meter shows 12.4. So I know my battery is good. I push in the key I can hear the choke click. But nothing. Went to the starter relay got 12.7 volts to the relay, check for polarity got polarity. The starter was rebuilt so I know it's not the starter. I just can't get it to say nothing. What are the symptoms of a bad starter relay. All I did was test to have 12.7 volts to the relay and I made sure my voltage did not drop well turning the key. So my problem is either in the key switch or the starter relay... is there a test for the starter relay thanks Mav
