I have the same problem, can you disconnect the alam from the oil sensor , if so how? Regards,Re: Mercury Alarm Codes, 89 150 Hp Black Max
i had a problem like that with my 150 merc, it was a bad ignition module, there are two and its better to change both at the same time since they are about 300 a piece, if you only change one the other could send a bad signal and short them both out then you'll wind up buying three of them, good luck!
