Mercury Autoblend question
Spillman1979
Guys, do I keep it or pitch it. It did work but now I don't have low level alarm. Just needing help.
Spillman1979
Do I need to do anything special , to unhook it from the motor. It's an 87 classic 50 45hp.
sam am I
Keeping mine!!...........Some of the "go faster" guys will suggest taking them out cuz they run on the edge and over heat things but, in the same breath say/do "keep them in" if they run the engine in the "norms" not over heating. I run on the line only occasionally and had never over heated.
I tore my engine down few years back and after 23 yrs, had scuffing in a few holes. The infamous "plastic gear" teeth were still in perfect shape. I rebuilt the motor from the needle bearing's up, replaced the gear for general purposes just like I did with seals and such. I put every piece of the 23 year old oiler components under a microscope......literally.
What I believe through some moderate research, experience and evidence.......... The primary failure mode (there are outlier's) is that the "coupler" (high impact thermal plastic) melts down under stress of heat (over tach'ing, plugged water passageways, shot impellers, low lube, etc, etc) and seizes in its journal. The gear continues to try to rotate as of course the engine continues to run. The frozen/seized coupler then reflects too much load on the gears teeth via the drive gear and the gear's teeth sheer/strip!! It's my theory and I'm sticking to it...............
My experience/observation with every aspect of my entire pre-mix components (more limited then some here that have merc in their blood) I saw/have a system that is very robust and engineered actually quite well.
IME/O, If ya don't overheat/modify the engine and you don't allow oil hose/s to break/fail, you'll be perfectly fine for many years to come with it. It's run since 87 and it'll continue to run if you maintain it properly.
A lawyer told me once............"Ask 10 different lawyer's the same question and you'll get 10 different answers" Go figure..........
flyingscott
th
This is an autoblend system is this what you have. If it is you can't get it in the garbage fast enough. It's been a long since I have seen one maybe a manual will help you.
Walk to the nearest fence.-----Then throw it over the fence as far as you can.
flyingscott
I think you can just unplug the electrical from the motor and reroute the fuel lines to bypass the tank and make sure it is mixed 50-1. I think the dealers used to call them autoblows.
sam am I
That is an entirely different beast!!! Sry Spill, thought you were referring to the "other mixing method" I'll go back to sleep
jimmbo
Premix guarantees oil in the fuel, provided you remember to add it, and at the proper ratio. That autoblend first came out in late 80s, even it never failed, by now it probably would need some TLC, as in new diaphragms and gaskets.
