Thank you for your reply Scott. IS the gearing different ? Does it turn out the same RPM? Is it not advisable to use as a main power on a small aluminum boat? I am looking for a prop for it, the four blade is shot and am wondering if a higher pitch 3 blade prop will work better for my application. It was previously used as a kicker on a 20 foot or so Whaler.
Size / weight of your boat ?
It appears that motor had a 5000-6000 rpm range, and a 2.08 : 1 gear ratio.
9.9 BigFoot, had a 2.42 : 1 gear ratio.
Yes the engine will run the same rpm, but the prop will turn slower with that gearing.
It should be fine on a 12 - 15' boat, with the right prop. 3 blade should work.
If you boat is a bit heavy, perfect.
If your boat is very light, and you don't need the extra gearing, you could see an approximate 15% loss in top speed.
So, a few mph loss.
