Mercury Carburetor floats
CaptJackM
Hi,<br /><br /><br />I am trying to find a float for a carburetor that I believe was made by Tillotson for Mercury Marine (can someone verify this for me?). The carburetor number is BC1-C. The Mercury outboard is year model 1980, 25 HP, serial number is 5972598, and I believe the the Mercury part number for the float is either 1399-8139 or 1399-8655. <br /><br />Perhaps someone knows of a way to retrofit another float into the carb? Perhaps with another float bowl?<br /><br />Numbers that I find on the carburetor itself:<br /><br /><br />123<br /><br />8496<br /><br />219B60<br /><br />To see a picture of the carburetor, please see this page:<br /><br /> http://www.mercurypartsexpress.com/...ection/ServiceParts/PartSelectionframeSet.asp <br /><br />Mercury Marine shows the float no longer available. I am hoping to find someone that knows about these carbs, that can help me find the part. I am thinking that there has to be an aftermarket or retrofit float, or even some new old stock out there to replace the original.<br /><br />Can someone please help?<br /><br />email me at CaptJacksNet@msn.com<br /><br />Any help will be appreciated.
WillyBWright
Re: Mercury Carburetor floats
Welcome to iboats. :) <br /><br />Not a Tillotson. Made by Merc. I imagine they outsourced the foat, so maybe something else might fit, but I have no idea what. Is there a manufacturer embossed in the plastic? You need the 8655. I don't have info on availability, but if Merc can't get you one, about your only choice is a used one. Good luck.
mudrow
Have you tried mercruiserparts.com through BAM Marine. Ir is sometimes hard to figure out what HP really is listed but they have about everything for every motor.
