Hey guys,
I have a few questions regarding my 1988 Mercury Classic 50 45 hp outboard. I just bought a flats boat with intentions to restore it. I am about half way done and I need some info to finish up some of the mechanical issues needing to be fixed. The outboard I have is sitting right now and from what I understand, it should run after I clean the carbs. Heres a list of questions you guys could help me with.
What kind of throttle control do I need that will be compatible with this engine? (my console has a hole cut for a top mount control box)
Can I start the engine without the control box and get it running until I have the control box. If so, how?
Do you think I should have the compression checked before I put it on the water? Or at least bring it to a mechanic to make sure I won't end up getting towed in?
Does anyone know if this particular motor had trim and tilt on it? It appears to have some sort of hydrolic cellinoid but I'm not sure if thats for the trim.
Pics and answers are greatly appreciated.
Thanks so much,
fishinick
Thanks so much,
fishinick
