keagernaught
- Joined
- Feb 27, 2020
- 14
Ignition Control Wiring Mercury 650
Hey Group,
I have a new topic about a new push-to-choke ignition switch I purchased for the 12V DC ignition system. It is aftermarket and it is marketed as a Magneto ignition system. I assume that will will function the same as a regular ignition system as long as I get the wires on the correct terminals.
The motor:
1971 Mercury 650 4cyl S/N: 2870742
What I do know:
Red- 12V DC Battery
Black- Ground
Yellow- Start
White- Ignition Accessory
Pink- Ignition Kill
Gray- Choke
The Magneto ignition control has 6 Terminals:
B- Battery
C- Choke
I- Ignition
S- Start
MA- Magneto
M- Magneto
I assume that it will work in the same way and I will show how I plan to connect the ignition control,
Red - B (Battery)
Black - M
White - I (ignition)
Yellow - S (Start)
Pink - MA
Gray - C (Choke)
I also plan to add a kill switch to the system and I believe I can connect those to the M and MA terminals to bridge the kill wire directly to ground.
Is this wiring accurate? Also will the kill switch be safe and not cause damage to the ignition coil?
-Thank You in advance.
Hey Group,
The motor:
What I do know:
Red- 12V DC Battery
Black- Ground
Yellow- Start
Pink- Ignition Kill
Gray- Choke
B- Battery
C- Choke
I- Ignition
S- Start
MA- Magneto
M- Magneto
Red - B (Battery)
Black - M
Yellow - S (Start)
Pink - MA
Gray - C (Choke)
