mercury controls
bobkyle2
im trying to get a mercury classic 3000 throttle control apart to get it out of the boat... Ive taken like every bolt out i can find... Is there a trick to getting them apart..
Texasmark
Re: mercury controls
Big laugh here sir. I got sick and tired of my 3000 and finally bit the bullet and bought a new one based upon the 2000 original design, but much improved. It took me a couple of hours to just get the 3 mounting screws off and I still couldn't get the shift/throttle handle off, and yes I removed the set screw. So I got out my reciprocating saw, put a 24T bi-metallic blade in her and sawed the sucker off.....and it has been kept in a garage and never used in salt water. Phew what a job and boy is the new one really sweet. Should have done it years ago.
HTH
Mark
matth121
so what was it that your saw cut through? I mean what did it end up being that was holding it on? im sure mine was different than yours, but I also had a rough time getting it off after removing the screws. Turned out to be paint in my case, it was just stuck there.
Texasmark
Funny, I don't remember. I had the control loose and to get it out of the triangular hole in the boat, the lever HAD to come off. I popped the set screw and applied a serious amount of high quality penetrating oil to everything associated that I could see. After a good soaking, I tried to prise it off with 2 very large screw drivers, then a hammer on the screwdrivers and finally the saw. I think I put the blade between the handle and the control housing as it was the smallest diameter and all that diameter had to come off anyway. I was surprised that the saw worked it's way through it very easily considering the fact that I was sawing metal.
Mark
bobkyle2
Damnerzzz ... lol... Well i crawled around.. wiggled more than i have ever wiggled getting to screws in the back.. Ive got every screw i could find out... and it wont budge...
bobkyle2
Im just trying to solve the problem on my boat it doesnt have a temp or oil alarm.. And with this new motor i was wanting the alarm... So im going to break out the schematics and see if i can find a way to wire the alarm into my controls i guess
matth121
do either of you or anyone out there have install instructions for the 3000? maybe you could reverse engineer them to find out whats holding it.
bobkyle2
None of my merc books has that set up in it...
